I am having issues running the I2c display on raspberry pi os lite. I have the I2c and spi enabled, and it shows up on i2c bus 1 and address is 27. Trying to implement this code. Any help would be appreciated.
Thank you
# Import LCD library
from RPLCD import i2c
# Import sleep library
from time import sleep
# constants to initialise the LCD
lcdmode = 'i2c'
cols = 20
rows = 4
charmap = 'A00'
i2c_expander = 'PCF8574'
# Generally 27 is the address;Find yours using: i2cdetect -y 1
address = 0x27
port = 1 # 0 on an older Raspberry Pi
# Initialise the LCD
lcd = i2c.CharLCD(i2c_expander, address, port=port, charmap=charmap,
cols=cols, rows=rows)
# Write a string on first line and move to next line
lcd.write_string('Hello world')
lcd.crlf()
lcd.write_string('IoT with Vincy')
lcd.crlf()
lcd.write_string('Phppot')
sleep(5)
# Switch off backlight
lcd.backlight_enabled = False
# Clear the LCD screen
lcd.close(clear=True)
