I start with the fact I’m confused with the forum structure, pinned posted with category explanations aren’t filled up.
I followed the guideline to flash the boot image first, then downloaded base Ubuntu 22.04.4 with +arm64 suffix (for UEFI boards). I tried to login, but ubuntu/ubuntu pair doesn’t work and with root/root and attempt to change password I get:
Ubuntu 22.04.3 LTS arm64 ttyAML0
arm64 login: root
Password:
You are required to change your password immediately (administrator enforced).
Changing password for root.
Current password:
Authentication token manipulation error
arm64 login:
What’s wrong with the image?
