How To Find Board Temperature Sensor Readings
Linux temperatures at exposed to userspace through the thermal class. You will find virtual files called temp within the sysfs thermal class directories:
cat /sys/class/thermal/thermal_zone0/temp
Some boards and chips will have multiple temperature sensors enumerated in multiple directories under /sys/class/thermal/ eg thermal_zone1, thermal_zone2, etc.
Hi,
When runing
or
sudo cat /sys/class/thermal/thermal_zone0/temp
it returns:
cat: /sys/class/thermal/thermal_zone0/temp: No such file or directory
on a fresh install of 2022-09-22-raspbian-bullseye-arm64-lite+aml-s905x-cc.0.img on a LePotato
What could be wrong?
Thank you.
This was a kernel bug. It’s been fixed.
