The IR receivers on Libre Computer boards are supported through the standard Linux Infrared Remote Control (LIRC) stack.
Below are some resources on setting up LIRC.
To get raw signals to quickly test the IR, run evtest.
Hello, I’ve been trying to get the IR receiver to work. Does it need to be enabled, like on the raspberry pi? I couldn’t find any documentation on what I would need to enable. evtest runs, but it doesn’t seem to pick up my remote.
Which board are you using?
The Le Potato AML-S905X-CC
This works out of the box. You need to select the right device with evtest.
I’m running evtest on a fresh install of Raspbian. It says that it’s testing and waiting for input, but pointing an IR remote at the receiver and pushing buttons yields no results.
You have to select the right device with evtest. Make sure your remote is IR and not some other protocol like BT.
/dev/input/event6, which is meson-ir.
The remote is the remote from an older television. It is definitely IR and not Bluetooth
It has to be a supported carrier frequency and remote code. Make and model?
CurtisMathes Tronics
The remote works to turn on the television it came with.
I know it’s IR because it’s an older remote and television from being IR was used in remotes, and also it has a bulb on the front and checking the bulb with my phone camera and pressing a button I can see it flashing in my phone’s camera app.
Test the voltage on the GPIO line from the IR. It should change with IR signal. Make sure you have all the keytables for IR enabled so it can detect as many protocols as possible.
How do I enable all the keytables for IR?
I would like to connect TSOPxx IR receiver to GPIO header pin to receive IR signals due to Le Potato onboard IR is not suitable for my enclosure. Do I need to create a custom device overlay for that purpose? Couldn’t find information for this.
Target: Enable IR receiver on Le Potato (AML-S905X-CC) using Pin 35 (GPIOX_7) of the 40-pin header (referred to as 7J1). Overlay Name: gpio-ir-7j1-35
Prerequisites:
git installed (sudo apt install git or equivalent).make installed (often part of build-essential: sudo apt install build-essential or equivalent).sudo apt install device-tree-compiler or equivalent).Steps:
libretech-wiring-tool:git clone https://github.com/libre-computer-project/libretech-wiring-tool.git
cd libretech-wiring-tool
.dts File: Create the device tree source file for the overlay within the repository structure.libre-computer/aml-s905x-cc/dt/gpio-ir-7j1-35.dtsmkdir -p libre-computer/aml-s905x-cc/dt
nano libre-computer/aml-s905x-cc/dt/gpio-ir-7j1-35.dts
/dts-v1/;
/plugin/;
* Device Tree Overlay for Le Potato (AML-S905X-CC)
* Enables GPIO IR Receiver on Header 7J1 Pin 35 (GPIOX_7)
* Pinctrl: bias-pull-up inside mux, input-enable removed per feedback.
* Uses the standard Linux 'gpio-ir-receiver' kernel driver/module.
* Connect the IR receiver's DATA pin to Header 7J1 Pin 35 (GPIOX_7).
* Connect VCC to 3.3V (Pin 1 or 17) and GND to GND (e.g. Pin 6, 9, 14...).
* Based on Libre Computer mapping: GPIOX_7 = Pin 35 on 40P Header (7J1)
* Filename: gpio-ir-7j1-35.dts (for libretech-wiring-tool)
// Compatible with the base device tree for Le Potato
compatible = "amlogic,s905x", "amlogic,meson-gxl";
// Fragment 1: Define the IR receiver device node
fragment@0 {
target-path = "/"; // Add node to the root
__overlay__ {
// Unique node name incorporating header and pin
ir_recv_7j1p35: ir-receiver@7j1p35 {
compatible = "gpio-ir-receiver";
// Reference the GPIO pin: Controller (&gpio), Pin (GPIOX_7), Flags (1 = Active Low)
// GPIOX_7 -> Kernel Pin 87. Active low (1) for typical IR receivers.
gpios = <&gpio 87 1>; // GPIOX_7 (mapped to Pin 35), Active Low (1)
// Reference the pin control configuration defined below
pinctrl-names = "default";
pinctrl-0 = <&ir_recv_7j1p35_pins>; // Link to the pinctrl state
status = "okay"; // Enable this device
// Fragment 2: Configure the pin control state for the GPIO
fragment@1 {
// Target the peripheral pin controller node. '&pinctrl_periphs' is typical for S905X.
target = <&pinctrl_periphs>;
__overlay__ {
// Define the pin control state for the IR receiver pin 7J1 Pin 35 (GPIOX_7)
ir_recv_7j1p35_pins: ir-recv-7j1p35-pins { // Unique pinctrl node name
// Define the pin multiplexing and configuration within mux block
mux {
pins = "GPIOX_7"; // Specify pin for muxing
bias-pull-up; // Apply pull-up (placed here per user request)
libretech-wiring-tool repository, run make. This compiles the .dts files into binary .dtbo overlays using dtc.# Ensure you are in the libretech-wiring-tool directory
make
ldto): Use the ldto shell script located in the repository’s root directory to check if the newly compiled overlay is recognized.# Run with sudo from the libretech-wiring-tool directory
sudo ./ldto list
# Confirm that `gpio-ir-7j1-35` appears in the list for `aml-s905x-cc`
enable): Use the enable command with the ldto script. This applies the overlay temporarily until the system reboots. Please note that if used with busses, the bus numbers might not match up with the merge command of ldto script.# Run with sudo from the libretech-wiring-tool directory
sudo ./ldto enable gpio-ir-7j1-35
dmesg | grep -i irls /dev/input/by-path/*-ir-receiver-*ir-keytable:sudo apt update && sudo apt install ir-keytable # If needed
sudo ir-keytable # Status
sudo ir-keytable -t # Test receiving`Confirm you see scan codes when pressing remote buttons.
merge):merge command.enable.# Run with sudo from the libretech-wiring-tool directory
# *** Ensure the overlay was tested successfully first! ***
sudo ./ldto merge gpio-ir-7j1-35
sudo reboot
