I have a probleme on my potato, I can run him without a freeze and all time I need to restart him, I don’t know why but the blue led stop and my screen freeze, I use Debian, and I have a 5v 2.5A a external keyboard and a ethernet cable plug in the board
Without more logs, it’s impossible to tell whether it’s power, board, MicroSD card, temperature, or some other reason.
What is the exact state of the board when it freezes and what is the state of the LEDs?
See Libre Computer Board Debug Serial UART Connection and Setup Guide
All the led are on except the blue one, the problems arrive when I try to download app in Debian, do you know if there is some updates for the firmware or something else, I didn’t have uart cable but I sure there is another option to fix that
What is the temperature of the board when it happens? Is there a heatsink on the device?
There is no heat skin and the board is not to hot but it’s not to cold middle temp, but when I try to execute a commande like apt-get update, it’s heating
It could be a bad MicroSD card or high temperature. Without more monitoring or logs, we cannot help you.
I have a Netcat 8GB HC, and for the heat I don’t know Do you have a tool or something else ? temperature when he sleep 40°C after a command, 50°C when I have try to install apache2
dmesg logs and watch -n 1 sensors command
For dmesg :
[ 41.918798] hid-generic 0003:1A2C:4094.0002: input,hidraw1: USB HID v1.10 Device [SEMICO USB Keyboard] on usb-xhci-hcd.1.auto-1.3/input1
[ 257.886645] meson8b-dwmac c9410000.ethernet end0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 257.892790] IPv6: ADDRCONF(NETDEV_CHANGE): end0: link becomes ready
[ 2291.264105] BTRFS warning (device mmcblk1p2): csum failed root 5 ino 34027 off 131072 csum 0x8941f998 expected csum 0x5aae6d2c mirror 1
[ 2291.264100] BTRFS warning (device mmcblk1p2): csum failed root 5 ino 34027 off 0 csum 0x8941f998 expected csum 0x240e1b86 mirror 1
[ 2291.264133] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 0, flush 0, corrupt 27, gen 0
[ 2291.270640] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 0, flush 0, corrupt 28, gen 0
[ 2291.273651] BTRFS warning (device mmcblk1p2): csum failed root 5 ino 34027 off 0 csum 0x8941f998 expected csum 0x240e1b86 mirror 1
[ 2291.323391] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 0, flush 0, corrupt 29, gen 0
[ 2291.332752] BTRFS warning (device mmcblk1p2): csum failed root 5 ino 34027 off 0 csum 0x8941f998 expected csum 0x240e1b86 mirror 1
[ 2291.341402] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 0, flush 0, corrupt 30, gen 0
For watch -n 1 sensors:
scpi_sensors-isa-0000
Adapter: ISA adapter
aml_thermal: +44.0°C
Your MicroSD card needs to be replaced. It’s corrupting data. See Troubleshooting MicroSD Card Performance and Recommended MicroSD Cards
