Signatures were invalid: EXPKEYSIG 2E5FB7FC58C58FFB
I have an Le Potato AML-S905X-CC. It is a V1. I have just created an image on SD card, after it was done booting up. Ran and apt update and there are some following errors.
The image in question is: 2023-10-10-raspbian-bookworm-arm64-lite+aml-s905x-cc.img.xz
Err:5 Index of /repo/ linux InRelease
The following signatures were invalid: EXPKEYSIG 2E5FB7FC58C58FFB deb.libre.computer contact+deb@libre.computer
Could anyone help troubleshoot the error?
Kit
We need to update the base images because they didn’t include the libretech-keyring package. Those keyrings have expired causing the error you see.
You can fix it by manually installing the package:
wget https://deb.libre.computer/repo/pool/main/libr/libretech-keyring/libretech-keyring_2024.05.19_all.deb
sudo dpkg -i libretech-keyring_2024.05.19_all.deb
sudo apt update
We will update the base images to include this package by default.
Thank you kindly. I actually did cheated I just copied libre-computer-deb.gpg from another working Le Potato.
But thank you for the method you provided.
Thank you,
Kit
Can confirm, This I had the same issue and this resolved it very quickly.
Thank you!
I have downloaded Raspbian Images (full for AMLOGIC Le Potato) and the issue is still present.
Yes i have seen that. At this time before updating, i would run this fix.
sudo apt update
I know Libre has stated they are going to update the images to have this compiled in them. Sometimes it takes time to confirm the image after compiling Linux.
Any word on when you are going to update the base images? The current images fail the same way. If you don’t plan to do this soon (it’s been more than a year), it would be nice to at least add a link to this post or just the instructions for updating the libre repository signature to the appropriate downloads web pages (e.g. https://libre.computer/products/roc-rk3328-cc/) so that each user doesn’t have to discover this problem the hard way and go searching for a solution.
Still not updated! Over a year later.
Thanks fixed the issue I had on my Renegade running OMV!
and still not updated :wink:
The suggested workaround worked for me.
I would also like to add my request that you update the images.
Thanks
I’ve came to this page when I need to install a new system since debian is the most reliable that has the ldto binary on it so I can set up i2c. I know these are old, but they do the job and are built like old buicks. The deb file above is now in a 404 state. I know it sucks to maintain stuff for a really long time, but your hardware lasts. Any chance you can put that back up?
for those having trouble getting the .deb file, if you go to https://deb.libre.computer/repo/pool/main/libr/libretech-keyring in your browser you’ll see the current filename, and you can substitute it in the above commands to get the current files.
