Hi there,
I installed 2023-10-10-raspbian-bookworm-arm64-full+aml-s905x-cc.img on my new AML-S905X-CC-V2. I started with a SanDisk UltraPLUS 32 GB and had some errors. Then i bought a Samsung PRO Plus and tried installing the same image.
On macOS I used the following command: sudo dd if=/Users/USERNAME/Downloads/2023-10-10-raspbian-bookworm-arm64-full+aml-s905x-cc.img of=/dev/disk4 bs=4M status=progress
I ran the same from an Ubuntu machine as well just to be sure that it’s not a quirk with macOS.
When running sudo dmesg | grep mmc I get:
[ 3.539240] meson-gx-mmc d0074000.mmc: Looking up vmmc-supply from device tree
[ 3.539421] meson-gx-mmc d0074000.mmc: Looking up vqmmc-supply from device tree
[ 3.539625] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
[ 5.144468] meson-gx-mmc d0072000.mmc: Looking up vmmc-supply from device tree
[ 5.146276] meson-gx-mmc d0072000.mmc: Looking up vqmmc-supply from device tree
[ 5.146445] meson-gx-mmc d0072000.mmc: Got CD GPIO
[ 5.394507] mmc1: non-supported SD ext reg layout
[ 5.394630] mmc1: new ultra high speed SDR104 SDXC card at address 0001
[ 5.404013] mmcblk1: mmc1:0001 FD4Q9 119 GiB
[ 5.414606] mmcblk1: p1 p2
[ 5.483718] BTRFS: device label rootfs devid 1 transid 1272 /dev/mmcblk1p2 scanned by (udev-worker) (189)
[ 7.286657] BTRFS info (device mmcblk1p2): using crc32c (crc32c-generic) checksum algorithm
[ 7.289554] BTRFS info (device mmcblk1p2): disk space caching is enabled
[ 7.301086] BTRFS info (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 19, flush 0, corrupt 3, gen 0
[ 7.311033] BTRFS info (device mmcblk1p2): enabling ssd optimizations
[ 7.312171] BTRFS info (device mmcblk1p2): start tree-log replay
[ 9.975483] BTRFS info (device mmcblk1p2: state M): use zstd compression, level 3
[ 27.144888] I/O error, dev mmcblk1, sector 3835280 op 0x0:(READ) flags 0x0 phys_seg 5 prio class 2
[ 27.145343] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 20, flush 0, corrupt 3, gen 0
[ 27.145667] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 21, flush 0, corrupt 3, gen 0
[ 27.145710] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 22, flush 0, corrupt 3, gen 0
[ 27.145746] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 23, flush 0, corrupt 3, gen 0
[ 27.783043] BTRFS warning (device mmcblk1p2): csum failed root 5 ino 322226 off 55721984 csum 0xaa4f9a5a expected csum 0xb27f519b mirror 1
[ 27.783089] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 23, flush 0, corrupt 4, gen 0
[ 35.598503] I/O error, dev mmcblk1, sector 6724456 op 0x0:(READ) flags 0x4000 phys_seg 37 prio class 2
[ 35.598541] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 24, flush 0, corrupt 4, gen 0
[ 35.598561] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 25, flush 0, corrupt 4, gen 0
[ 35.598571] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 26, flush 0, corrupt 4, gen 0
[ 35.598579] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 27, flush 0, corrupt 4, gen 0
[ 35.598588] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 28, flush 0, corrupt 4, gen 0
[ 35.598597] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 29, flush 0, corrupt 4, gen 0
[ 35.598605] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 30, flush 0, corrupt 4, gen 0
[ 583.518335] I/O error, dev mmcblk1, sector 4898600 op 0x0:(READ) flags 0x0 phys_seg 5 prio class 2
[ 583.518372] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 31, flush 0, corrupt 4, gen 0
[ 601.757826] I/O error, dev mmcblk1, sector 2147728 op 0x0:(READ) flags 0x0 phys_seg 43 prio class 2
[ 601.757865] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 32, flush 0, corrupt 4, gen 0
[ 601.757883] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 33, flush 0, corrupt 4, gen 0
[ 601.757892] BTRFS error (device mmcblk1p2): bdev /dev/mmcblk1p2 errs: wr 0, rd 34, flush 0, corrupt 4, gen 0
After setting the right signing keys I want to update everything but after some time I will get error messages the file system turned readonly.
sudo apt-get --only-upgrade install chromiu
Paketlisten werden gelesen... Fertig
Abhngigkeitsbaum wird aufgebaut... Fertig
Statusinformationen werden eingelesen... Fertig
Die folgenden Pakete wurden automatisch installiert und werden nicht mehr bentigt:
chromium-browser-l10n chromium-codecs-ffmpeg-extra flashrom libftdi1-2
libjaylink0 librtimulib-dev linux-kbuild-6.1 python3-sense-hat
Verwenden Sie sudo apt autoremove, um sie zu entfernen.
Die folgenden zustzlichen Pakete werden installiert:
chromium chromium-browser-l10n chromium-common chromium-l10n
chromium-sandbox fonts-liberation libc++1-16 libc++abi1-16
libharfbuzz-subset0 libminizip1 libunwind-16 libupower-glib3 libxnvctrl0
notification-daemon upower
Vorgeschlagene Pakete:
chromium-shell chromium-driver clang
Die folgenden NEUEN Pakete werden installiert:
chromium chromium-common chromium-l10n chromium-sandbox fonts-liberation
libc++1-16 libc++abi1-16 libharfbuzz-subset0 libminizip1 libunwind-16
libupower-glib3 libxnvctrl0 notification-daemon upower
Die folgenden Pakete werden aktualisiert (Upgrade):
chromium-browser chromium-browser-l10n
2 aktualisiert, 14 neu installiert, 0 zu entfernen und 352 nicht aktualisiert.
Es mssen 153 MB an Archiven heruntergeladen werden.
Nach dieser Operation werden 1.642 kB Plattenplatz zustzlich benutzt.
Mchten Sie fortfahren? [J/n] J
Holen:1 http://deb.debian.org/debian bookworm/main arm64 libunwind-16 arm64 1:16.0.6-15~deb12u1 [53,1 kB]
Holen:2 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-browser-l10n all 1:130.0.6723.116-1~deb12u1+rpt1 [97,6 kB]
Holen:3 http://deb.debian.org/debian bookworm/main arm64 libc++abi1-16 arm64 1:16.0.6-15~deb12u1 [89,4 kB]
Holen:4 http://deb.debian.org/debian bookworm/main arm64 libc++1-16 arm64 1:16.0.6-15~deb12u1 [269 kB]
Holen:5 http://deb.debian.org/debian bookworm/main arm64 libharfbuzz-subset0 arm64 6.0.0+dfsg-3 [1.902 kB]
Holen:6 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-l10n all 1:130.0.6723.116-1~deb12u1+rpt1 [17,8 MB]
Holen:7 http://deb.debian.org/debian bookworm/main arm64 libminizip1 arm64 1.1-8+deb12u1 [19,8 kB]
Holen:8 http://deb.debian.org/debian bookworm/main arm64 libxnvctrl0 arm64 525.85.05-3~deb12u1 [13,4 kB]
Holen:9 http://deb.debian.org/debian bookworm/main arm64 fonts-liberation all 1:1.07.4-11 [828 kB]
Holen:10 http://deb.debian.org/debian bookworm/main arm64 libupower-glib3 arm64 0.99.20-2 [34,2 kB]
Holen:11 http://deb.debian.org/debian bookworm/main arm64 notification-daemon arm64 3.20.0-4+b1 [59,5 kB]
Holen:12 http://deb.debian.org/debian bookworm/main arm64 upower arm64 0.99.20-2 [77,6 kB]
Holen:13 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-browser all 1:130.0.6723.116-1~deb12u1+rpt1 [97,6 kB]
Holen:14 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-common arm64 1:130.0.6723.116-1~deb12u1+rpt1 [20,1 MB]
Holen:15 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium arm64 1:130.0.6723.116-1~deb12u1+rpt1 [112 MB]
Holen:16 http://archive.raspberrypi.com/debian bookworm/main arm64 chromium-sandbox arm64 1:130.0.6723.116-1~deb12u1+rpt1 [105 kB]
Es wurden 153 MB in 14 s geholt (11,0 MB/s).
Changelogs werden gelesen... Fertig
(Lese Datenbank ... 128438 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../00-chromium-browser-l10n_1%3a130.0.6723.116-1~deb12u1+rpt1_all.deb ...
Entpacken von chromium-browser-l10n (1:130.0.6723.116-1~deb12u1+rpt1) ber (116.0.5845.102-rpt1) ...
Vormals nicht ausgewhltes Paket chromium-l10n wird gewhlt.
Vorbereitung zum Entpacken von .../01-chromium-l10n_1%3a130.0.6723.116-1~deb12u1+rpt1_all.deb ...
Entpacken von chromium-l10n (1:130.0.6723.116-1~deb12u1+rpt1) ...
Vorbereitung zum Entpacken von .../02-chromium-browser_1%3a130.0.6723.116-1~deb12u1+rpt1_all.deb ...
Entpacken von chromium-browser (1:130.0.6723.116-1~deb12u1+rpt1) ber (116.0.5845.102-rpt1) ...
Vormals nicht ausgewhltes Paket libunwind-16:arm64 wird gewhlt.
Vorbereitung zum Entpacken von .../03-libunwind-16_1%3a16.0.6-15~deb12u1_arm64.deb ...
Entpacken von libunwind-16:arm64 (1:16.0.6-15~deb12u1) ...
Vormals nicht ausgewhltes Paket libc++abi1-16:arm64 wird gewhlt.
Vorbereitung zum Entpacken von .../04-libc++abi1-16_1%3a16.0.6-15~deb12u1_arm64.deb ...
Entpacken von libc++abi1-16:arm64 (1:16.0.6-15~deb12u1) ...
Vormals nicht ausgewhltes Paket libc++1-16:arm64 wird gewhlt.
Vorbereitung zum Entpacken von .../05-libc++1-16_1%3a16.0.6-15~deb12u1_arm64.deb ...
Entpacken von libc++1-16:arm64 (1:16.0.6-15~deb12u1) ...
Vormals nicht ausgewhltes Paket libharfbuzz-subset0:arm64 wird gewhlt.
Vorbereitung zum Entpacken von .../06-libharfbuzz-subset0_6.0.0+dfsg-3_arm64.deb ...
Entpacken von libharfbuzz-subset0:arm64 (6.0.0+dfsg-3) ...
Vormals nicht ausgewhltes Paket libminizip1:arm64 wird gewhlt.
Vorbereitung zum Entpacken von .../07-libminizip1_1.1-8+deb12u1_arm64.deb ...
Entpacken von libminizip1:arm64 (1.1-8+deb12u1) ...
Vormals nicht ausgewhltes Paket libxnvctrl0:arm64 wird gewhlt.
Vorbereitung zum Entpacken von .../08-libxnvctrl0_525.85.05-3~deb12u1_arm64.deb ...
Entpacken von libxnvctrl0:arm64 (525.85.05-3~deb12u1) ...
Vormals nicht ausgewhltes Paket chromium-common wird gewhlt.
Vorbereitung zum Entpacken von .../09-chromium-common_1%3a130.0.6723.116-1~deb12u1+rpt1_arm64.deb ...
Entpacken von chromium-common (1:130.0.6723.116-1~deb12u1+rpt1) ...
Vormals nicht ausgewhltes Paket chromium wird gewhlt.
Vorbereitung zum Entpacken von .../10-chromium_1%3a130.0.6723.116-1~deb12u1+rpt1_arm64.deb ...
Entpacken von chromium (1:130.0.6723.116-1~deb12u1+rpt1) ...
[ 314.505166] BTRFS: error (device mmcblk1p2: state A) in do_free_extent_accounting:2845: errno=-5 IO failure
[ 314.509513] BTRFS: error (device mmcblk1p2: state EA) in btrfs_run_delayed_refs:2149: errno=-5 IO failure
dpkg: Fehler beim Bearbeiten des Archivs /tmp/apt-dpkg-install-IGLU0g/10-chromium_1%3a130.0.6723.116-1~deb12u1+rpt1_arm64.deb (--unpack):
Extrahierte Daten fr ./usr/lib/chromium/chromium knnen nicht nach /usr/lib/chromium/chromium.dpkg-new kopiert werden: Es konnte nicht geschrieben werden (Das Dateisystem ist nur lesbar)
dpkg: Fehler beim Aufrumen:
Soeben entpackte Version von /usr/lib/chromium/chromium kann nicht entfernt werden: Das Dateisystem ist nur lesbar
Soeben entpackte Version von /usr/lib/chromium/chrome_200_percent.pak kann nicht entfernt werden: Das Dateisystem ist nur lesbar
Soeben entpackte Version von /usr/lib/chromium/chrome_100_percent.pak kann nicht entfernt werden: Das Dateisystem ist nur lesbar
Soeben entpackte Version von /usr/bin/chromium kann nicht entfernt werden: Das Dateisystem ist nur lesbar
Soeben entpackte Version von /etc/chromium.d/extensions kann nicht entfernt werden: Das Dateisystem ist nur lesbar
Soeben entpackte Version von /etc/chromium.d/default-flags kann nicht entfernt werden: Das Dateisystem ist nur lesbar
Soeben entpackte Version von /etc/chromium.d/apikeys kann nicht entfernt werden: Das Dateisystem ist nur lesbar
Soeben entpackte Version von /etc/chromium.d/README kann nicht entfernt werden: Das Dateisystem ist nur lesbar
/var/lib/dpkg/tmp.ci kann nicht auf sichere Weise entfernt werden: Das Dateisystem ist nur lesbar
dpkg: Fehler beim Bearbeiten des Archivs /tmp/apt-dpkg-install-IGLU0g/11-chromium-sandbox_1%3a130.0.6723.116-1~deb12u1+rpt1_arm64.deb (--unpack):
Fehler beim Sicherstellen, dass /var/lib/dpkg/reassemble.deb nicht existiert: Das Dateisystem ist nur lesbar
dpkg: Fehler beim Bearbeiten des Archivs /tmp/apt-dpkg-install-IGLU0g/12-fonts-liberation_1%3a1.07.4-11_all.deb (--unpack):
dpkg: Fehler beim Bearbeiten des Archivs /tmp/apt-dpkg-install-IGLU0g/13-libupower-glib3_0.99.20-2_arm64.deb (--unpack):
dpkg: Fehler beim Bearbeiten des Archivs /tmp/apt-dpkg-install-IGLU0g/14-notification-daemon_3.20.0-4+b1_arm64.deb (--unpack):
dpkg: Fehler beim Bearbeiten des Archivs /tmp/apt-dpkg-install-IGLU0g/15-upower_0.99.20-2_arm64.deb (--unpack):
dpkg: Fehler: Neue Datei /var/lib/dpkg/status-new kann nicht angelegt werden: Das Dateisystem ist nur lesbar
dpkg-deb: Fehler: einfgen-Unterprozess wurde durch Signal (Datenbergabe unterbrochen (broken pipe)) gettet
E: Sub-process /usr/bin/dpkg returned an error code (2)
W: Problem beim Entfernen (unlink) der Datei /var/cache/apt/pkgcache.bin - pkgDPkgPM::Go (30: Das Dateisystem ist nur lesbar)
I know it’s a bit annoying that this ins in german.
Means: dpgk: Error: New File /var/lib/dpkg/status-new can not be created: The filesystem is readonly.
When I reboot the system I goes away for a short time, but I never got a full upgrade going.
Is there anything I can do? I reinstalled the image several times and tried different debian images as well.
