The password is expired and needs to be changed on first setup or initialized by cloud-init. You cannot ssh to the box with an expired password since it’s a network security vulnerability. You need to set it up first.
when I connected an HDMI connector and monitor the monitor Just says no signal.
What then would be causing by monitor to not detect the signal from the board?
I reflashes the drive with Raspian just to see and i still get know signal. I have AML-S905X-CC it was able to flash it with the same ubuntu image, but with correct version for that board and had not issues.
so I have verified the monitor and cable are good. appears there is something wrong with the HDMI on board or connector. It will say no signal then screen shuts off and every so often it flashes and says no signal again.
Appears that was the issue. I found a monitor with a HDMI port and that did.
I’m curious, does the AML-S905X-CC support HDMI to DVI-D? when i connect with HDMI to DVI-D adapter it works fine. That was why I was thinking it was something with the HDMI connector.
But thank you very much for all you help. It is very much appreciated.
