I am having an issue in Raspbian on the LePotato with starting the vncserver service and running vncserver at all. I get the following log / error responses with each of the following commands. Tight VNC Server works fine for me but with the 8 character limit password among other things, I would rather use Real VNC Server (realvnc-vnc-server apt package) if possible. Any help or thoughts are appreciated!
sudo vncserver command outputs
VNC(R) Server 6.7.2 (r42622) ARMv6 (May 13 2020 19:34:20)
Copyright (C) 2002-2020 RealVNC Ltd.
RealVNC and VNC are trademarks of RealVNC Ltd and are protected by trademark
registrations and/or pending trademark applications in the European Union,
United States of America and other jurisdictions.
Protected by UK patent 2481870; US patent 8760366; EU patent 2652951.
See https://www.realvnc.com for information on VNC.
For third party acknowledgements see:
https://www.realvnc.com/docs/6/foss.html
OS: Raspbian GNU/Linux 10, Linux 6.0.19, aarch64
VNC(R) Server 6.7.2 (r42622) ARMv6 (May 13 2020 19:44:08)
<11> 2023-02-20T16:22:50.245Z bna Xvnc[1371]: VendorConfig: Error in Certificate "CN=GeoTrust Global CA,O=GeoTrust Inc.,C=US": X.509 Error: Certificate expired
<11> 2023-02-20T16:22:50.246Z bna Xvnc[1371]: VendorConfig: Error in Certificate "CN=GlobalSign,O=GlobalSign,OU=GlobalSign Root CA - R2": X.509 Error: Certificate expired
On some distributions (in particular Red Hat), you may get a better experience
by running vncserver-virtual in conjunction with the system Xorg server, rather
than the old version built-in to Xvnc. More desktop environments and
applications will likely be compatible. For more information on this alternative
implementation, please see: https://www.realvnc.com/doclink/kb-546
Running applications in /root/.vnc/xstartup
The virtual session failed to start. Session log:
XvncSession start time: 2023-02-20T16:22:50.289Z
Starting Xvnc
Waiting for Xvnc...
<11> 2023-02-20T16:22:50.359Z bna Xvnc[1376]: VendorConfig: Error in Certificate "CN=GeoTrust Global CA,O=GeoTrust Inc.,C=US": X.509 Error: Certificate expired
<11> 2023-02-20T16:22:50.360Z bna Xvnc[1376]: VendorConfig: Error in Certificate "CN=GlobalSign,O=GlobalSign,OU=GlobalSign Root CA - R2": X.509 Error: Certificate expired
<13> 2023-02-20T16:22:50.407Z bna Xvnc[1376]: ServerManager: Server started
Fatal server error:
VNC Server is not licensed correctly.
Connections will be prohibited until a valid subscription is applied.
<13> 2023-02-20T16:22:50.409Z bna Xvnc[1376]: ServerManager: Server stopped
Timed out waiting for Xvnc, last error: connect: No such file or directory (2)
sudo service vnc-x11-serviced status shows the following
β vncserver-x11-serviced.service - VNC Server in Service Mode daemon
Loaded: loaded (/lib/systemd/system/vncserver-x11-serviced.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2023-02-20 11:19:54 EST; 1h 1min ago
Main PID: 865 (vncserver-x11-s)
Tasks: 5 (limit: 1985)
Memory: 18.2M
CGroup: /system.slice/vncserver-x11-serviced.service
ββ 865 /usr/bin/vncserver-x11-serviced -fg
ββ 872 /usr/bin/vncserver-x11-core -service
ββ1016 /usr/bin/vncagent service 11
ββ1161 /usr/bin/vncserverui service 12
ββ1245 /usr/bin/vncserverui -statusicon 5
Feb 20 11:19:54 bna systemd[1]: Started VNC Server in Service Mode daemon.
Feb 20 11:19:54 bna vncserver-x11[872]: LogDestMem: Start replaying stored messages
Feb 20 11:19:54 bna vncserver-x11[872]: VendorConfig: Error in Certificate "CN=GeoTrust Global CA,O=GeoTrust Inc.,C=US": X.509 Error: Certificate expired
Feb 20 11:19:54 bna vncserver-x11[872]: VendorConfig: Error in Certificate "CN=GlobalSign,O=GlobalSign,OU=GlobalSign Root CA - R2": X.509 Error: Certificate expired
Feb 20 11:19:54 bna vncserver-x11[872]: LogDestMem: Finished replaying stored messages
Feb 20 11:19:54 bna vncserver-x11[872]: ServerManager: Server started
Feb 20 11:19:54 bna vncserver-x11[872]: ConsoleDisplay: Cannot find a running X server
Feb 20 11:19:59 bna vncserver-x11[872]: ConsoleDisplay: Found running X server (pid=915, binary=/usr/lib/xorg/Xorg)
