I just got a libre 905 and can not locate the debian image
You could always use Armbian’s readily available images for Bullseye Debian.
Raspbian is already 99% Debian. We will release Debian standalone soon.
I am using Debian finally it works ok but does not shutdown but restarts after shutting down.
thank you for replying
Birdman
thank you I will wait to test it out
Birdman
I have a shutdown button that works on my raspberry pie , it comes with a driver I will try that then .
Thank you Birdman
I just tried it. that did not work. Thanks anyway
birman
It does work. What happens when you run the command?
I rebooted and tried again and it works thank you very much
