This applies for unofficial images and older images from before 2023. Newer official images have resolved the shutdown issue.
There is no power button on the board. When shutdown is triggered, the default action of the board is to reboot. To avoid rebooting, run shutdown -H now which will halt the machine.
To power the machine back on, connect the RX pin to ground or hook it up to a switch or use ethernet WOL.
With my Raspbian image, 2022-09-22-raspbian-bullseye-arm64+aml-s905x-cc.img.xz, sudo shutdown -H does in fact shut down the system and it stays powered off.
Using the GUI Shutdown reboots the system. Minor point, but it was surprising the first time it happened.
Is it possible to disable the watchdog on images downloaded prior? Rather than having to “echo ‘V’ | sudo tee /dev/watchdog” every time I want to shut down the system?
We have disabled the watchdog by default for images since November. If you had an image from before, simply use the libretech-flash-tool to re-flash the bootloader.
Any idea on how install halt on Batocera and Lakka?
Thanks
EDIT
Never mind on Batocera is already installed, simply it is impossible shutdown the board, I can only unplug the AC when exclusively the red light is on…
