La Frite cant get it to boot
I have tried now, During the whole day, Non stop, From 07:00 in the morning until now, 23:56, And i cant get it to work.
I have a La Frite 1GB, I do not have the eMMC and i need to boot from an external ssd or an sd card connected via usb sd card adapter. I have used all of the correct flashing tools and done everything as its supposed to, But it never works, My la frite refuses to boot anything, The errors range from kernel panic etc etc. The boot switch is set to NOR.
I have tried multiple different PSUs , multiple different SD cards and the external SSD and just about every image available, It never works, Kernel panic, kernel out of sync, the problems are different everytime. I need help.
First of all, Which image is supposed to be used for the La Frite, Is it the image that ends with +arm64 or the one that ends with S905X?
Perhaps, Its not even possible to boot from USB and use USB connected as main storage. I dont understand. I have checked the common misshaps list a thousand times. This board is driving me crazy… One time i actually managed to boot into the raspbian install screen, but then it would freeze after a little while, all the time, usually when entering the user and password, Now i cant even replicate that. The one thing the board managed to do was update its bios, That worked without issue
See 1: Troubleshooting General Boot Issues
I have read this page multiple times and tried everything stated and made sure everything is correct multiple times. To no avail.
Can you help me understand the fail messeges and what could be causing them
I am experiencing persistent issues with my La Frite PCB and need help. I have already reviewed the common faults list multiple times and meticulously followed its recommendations without success.
Here is what I have tried so far:
  • Power Supplies: Tested 6 different power supplies, all rated at a minimum of 5V 3.0A.
  • Cables: Used 12 different micro USB cables.
  • Storage Media: Tried 5 SD cards (including going to the store, 1 hours ago and purchasing a new Sandisk Extreme as recommended, didnt work either) and one external SSD.
  • Flashing Tools: Used all recommended tools, including Win32 Disk Imager, macOS Disk Utility, and installing linux on an old computer just so i cold use Gnome Disk Utility on Linux, didnt work either…
  • Images: Tested 23 different images, primarily ARM64 but also some 905 images. The only successful boot occurred initially with Raspbian + 905.
In total, I have now attempted to boot into a functioning system over 100 times. Despite all these efforts, I encounter varying errors with no consistent pattern, and I am unable to identify the root cause. Could you please provide detailed troubleshooting guidance beyond the common fault list? I would greatly appreciate your support.
At this point, There must be something wrong with the board, Anything else has been switched out and ruled out, Well expect the images, since all images have been from the distro server but those has been guaranteed to work.
The normal process flow is as follows:
  1. Download Compressed Image (eg. file+model.img.xz) DONE
  2. Extract Compressed Image (eg. file.img) DONE
  3. Flash Extracted Decompressed Image to Bootable Storage Medium (MicroSD card) DONE
  4. Insert Bootable Storage Medium into Board DONE
  5. Provide Sufficient Power to Board DONE
  6. Board Boots u-boot Bootloader from Storage Medium DONE
  7. u-boot Bootloader Loads EFI Bootloader (GRUB) done
I never come furhter than this. Systemcd can never be booted.
9. EFI Bootloader Boots Linux
10. Linux Boots systemd
11. systemd starts services and applications
KERNEL PANIC, KERNEL OUT OF SYNC etc etc.
Have you updated to the latest firmware? Libre Computer Board BIOS/Firmware Update Images
Is there any errors on boot up from UART related to memory tuning? Libre Computer Board Debug Serial UART Connection and Setup Guide
