Requirements
- La Frite board
- eMMC 5.x module attached
- USB Type A to USB Type A cable
- Any Linux computer (not AMD) or SBC (Windows/Mac OS might work, untested)
Install the necessary tools and clone pyamlboot:
sudo apt install -y python3-usb
git clone --single-branch https://github.com/libre-computer-project/pyamlboot.git -b scripts
- Detach all peripherals including HDMI cable, USB devices, and MicroUSB power.
- Plug one end of the USB Type A cable into your computer/SBC with pyamlboot.
- Press and hold the K11/Uboot button on the board while attaching the other end of the USB Type A cable into the left USB port next to the IR sensor. Release button after the board lights up.
- Attach auxiliary power via MicroUSB if your computer/SBC does not provide enough. (Optional)
Below are two actions. Only run one of the following actions per connect. If you need to run a different action, power off the board completely (usually HDMI, MicroUSB, and USB Type A) and repeat from step 3.
To erase eMMC user partition table and bootloader, run the following:
sudo pyamlboot/run.sh aml-s805x-ac erase-emmc
# erases first 1MB of eMMC user hardware partition
# this includes any MBR/GPT partition table and bootloader
To turn eMMC into a virtual flash drive to flash images, run the following:
sudo pyamlboot/run.sh aml-s805x-ac ums-emmc
# exposes eMMC user hardware partition as a flash drive after 5 seconds
# you do not have to erase the eMMC first before flashing images
Wait 10 seconds and a virtual flash drive should appear to your Linux machine/SBC. You can use gnome-disk-imager or dd to flash any of our images directly to the eMMC. This method of dumping to eMMC is limited by the Porgrammable IO USB transfer mode which has a peak write speed of around 10MB/s.
There is a known issue with AMD machines timing out on USB transfers. We have yet to figure out a workaround so please use Intel machines or an SBC to do this. If anyone at AMD is reading this, please fix your USB please
