This has been added to the CI. You should see a new kernel update in 6 hours with support for this.
Update: it should be on the server. Please run sudo apt-update && sudo apt dist-upgrade.
I just hit this error an hr ago, thanks for getting the fix up before I could even ask about it
CIFS is working now after update.
Thank you for the continuing support of these SoC’s. Using this release I had problems getting an IP address using the La Frite so I installed the Debian Buster headless image and it works really well. I can now turn off my 100 Watt NAS where I had servers and instead use my La Frite that uses only 1.6 Watts.
Out of curiousity, will there be a Debian Bullseye headless image? With the Debian Buster working well at the moment I am affraid of upgrading it.
Probably by the end of this month. Supporting Debian is not difficult but our priorities are getting lower level stuff right. Once that is done, adding support takes a day at most.
I had a similar issue. Boots up in 3840x2160 resolution. I attempted to change in the display properties settings to 1920x1080 in hopes of speeding it up a bit (issues with Chromium install but that’s likely a user error).
When I click to apply the changes it does a reboot (as it should) but when the log in prompt appears it’s very sluggish. Mouse takes several seconds to responds and keyboard input is the same.
Assuming i screwed up somewhere I just burned the img again but same results. This is after the system completed its initial update.
Didn’t mean to hop into a thread but it is somewhat related.
Thanks.
If the 3D Mali GPU gets fed textures over 1920 pixels long or wide, the driver crashes and cause the entire system to slow down. Best to change resolution to 1920x1080 or lower and reboot.
It seems cloud-init is rerunning on each reboot for me. At least my hostname is being reset to the hostname configured by cloud-init. Is this expected?
getting the following error since a couple of days after ssh login: client_loop: send disconnect: connection reset
That’s just the SSH session dying due to either TCP timeout from network disconnection or your ISP forcing timing of an connection. You can try increasing the rate of alive packets.
how to do this? The board was running fine for month, now this happens and only on the Libre boards. My other raspberry -also running Ubuntu- are fine
Check your dmesg for network events. Make sure something else isn’t crashing. Post your log here. Otherwise, for SSH timeout, Google “ssh server keep alive”.
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.19.16-04046-g062726298e8a (autobuild@deb.libre.computer) (gcc (Debian 8.3.0-6) 8.3.0, GNU ld (GNU Binutils for Debian) 2.31.1) #1 SMP PREEMPT Sat Oct 15 07:43:35 UTC 2022
[ 0.000000] Machine model: Libre Computer AML-S905X-CC
[ 0.000000] efi: EFI v2.90 by Das U-Boot
[ 0.000000] efi: RTPROP=0x7ae89040 SMBIOS=0x7ae88000 RNG=0x5846d040 MEMRESERVE=0x5846c040
[ 0.000000] efi: seeding entropy pool
[ 0.000000] random: crng init done
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000006ac00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000000ffffff]
[ 0.000000] node 0: [mem 0x0000000001000000-0x0000000004ffffff]
[ 0.000000] node 0: [mem 0x0000000005000000-0x00000000072fffff]
[ 0.000000] node 0: [mem 0x0000000007300000-0x000000000fffffff]
[ 0.000000] node 0: [mem 0x0000000010000000-0x00000000101fffff]
[ 0.000000] node 0: [mem 0x0000000010200000-0x000000005846cfff]
[ 0.000000] node 0: [mem 0x000000005846d000-0x000000005846dfff]
[ 0.000000] node 0: [mem 0x000000005846e000-0x000000007ae87fff]
[ 0.000000] node 0: [mem 0x000000007ae88000-0x000000007ae8bfff]
[ 0.000000] node 0: [mem 0x000000007ae8c000-0x000000007ae8cfff]
[ 0.000000] node 0: [mem 0x000000007ae8d000-0x000000007ae90fff]
[ 0.000000] node 0: [mem 0x000000007ae91000-0x000000007deaffff]
[ 0.000000] node 0: [mem 0x000000007deb0000-0x000000007debffff]
[ 0.000000] node 0: [mem 0x000000007dec0000-0x000000007fe5afff]
[ 0.000000] node 0: [mem 0x000000007fe5b000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv0.2 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] percpu: Embedded 20 pages/cpu s43368 r8192 d30360 u81920
[ 0.000000] pcpu-alloc: s43368 r8192 d30360 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 516096
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.19.16-04046-g062726298e8a root=UUID=38ef9825-ab14-404b-913e-d7383ec826d9 ro noquiet splash vt.handoff=7
[ 0.000000] Unknown kernel command line parameters “noquiet splash BOOT_IMAGE=/boot/vmlinuz-5.19.16-04046-g062726298e8a”, will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 1685264K/2097152K available (12864K kernel code, 1734K rwdata, 5060K rodata, 3136K init, 468K bss, 149744K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000528] Console: colour dummy device 80x25
[ 0.001031] printk: console [tty0] enabled
[ 0.001072] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=96000)
[ 0.001096] pid_max: default: 32768 minimum: 301
[ 0.001162] LSM: Security Framework initializing
[ 0.001188] Yama: becoming mindful.
[ 0.001308] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001335] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.002585] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002624] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002691] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002825] rcu: Hierarchical SRCU implementation.
[ 0.002838] rcu: Max phase no-delay instances is 1000.
[ 0.003827] Remapping and enabling EFI services.
[ 0.004224] smp: Bringing up secondary CPUs …
[ 0.004719] Detected VIPT I-cache on CPU1
[ 0.004787] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.005356] Detected VIPT I-cache on CPU2
[ 0.005415] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.005944] Detected VIPT I-cache on CPU3
[ 0.005995] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.006070] smp: Brought up 1 node, 4 CPUs
[ 0.006141] SMP: Total of 4 processors activated.
[ 0.006153] CPU features: detected: 32-bit EL0 Support
[ 0.006163] CPU features: detected: 32-bit EL1 Support
[ 0.006176] CPU features: detected: CRC32 instructions
[ 0.006647] CPU: All CPU(s) started at EL2
[ 0.006684] alternatives: patching kernel code
[ 0.008035] devtmpfs: initialized
[ 0.013556] Registered cp15_barrier emulation handler
[ 0.013596] Registered setend emulation handler
[ 0.013613] KASLR enabled
[ 0.013781] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.013809] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.019820] pinctrl core: initialized pinctrl subsystem
[ 0.020179] regulator-dummy: no parameters, enabled
[ 0.020459] SMBIOS 3.0 present.
[ 0.020491] DMI: libre-computer aml-s905x-cc/aml-s905x-cc, BIOS 2022.07+ 07/01/2022
[ 0.020953] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.022153] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.022363] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.022518] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.022609] audit: initializing netlink subsys (disabled)
[ 0.022800] audit: type=2000 audit(0.020:1): state=initialized audit_enabled=0 res=1
[ 0.023843] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.023856] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.024140] cpuidle: using governor menu
[ 0.024356] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.024466] ASID allocator initialised with 32768 entries
[ 0.024482] HugeTLB: can optimize 4095 vmemmap pages for hugepages-1048576kB
[ 0.024497] HugeTLB: can optimize 127 vmemmap pages for hugepages-32768kB
[ 0.024510] HugeTLB: can optimize 7 vmemmap pages for hugepages-2048kB
[ 0.024523] HugeTLB: can optimize 0 vmemmap pages for hugepages-64kB
[ 0.035949] platform c883a000.hdmi-tx: Fixing up cyclic dependency with d0100000.vpu
[ 0.037201] platform cvbs-connector: Fixing up cyclic dependency with d0100000.vpu
[ 0.037599] platform hdmi-connector: Fixing up cyclic dependency with c883a000.hdmi-tx
[ 0.046501] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.046537] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.046551] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.046565] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.047818] fbcon: Taking over console
[ 0.048131] VCC_3V3: 3300 mV, enabled
[ 0.048298] reg-fixed-voltage regulator-vcc_3v3: VCC_3V3 supplying 3300000uV
[ 0.048425] VDDIO_AO18: 1800 mV, enabled
[ 0.048507] reg-fixed-voltage regulator-vddio_ao18: VDDIO_AO18 supplying 1800000uV
[ 0.048604] VDDIO_BOOT: will resolve supply early: vin
[ 0.048611] reg-fixed-voltage regulator-vddio_boot: Looking up vin-supply from device tree
[ 0.048624] VDDIO_BOOT: supplied by VCC_3V3
[ 0.048632] VCC_3V3: could not add device link regulator.3: -ENOENT
[ 0.048688] VDDIO_BOOT: 1800 mV, enabled
[ 0.048768] reg-fixed-voltage regulator-vddio_boot: VDDIO_BOOT supplying 1800000uV
[ 0.049156] iommu: Default domain type: Passthrough
[ 0.049450] SCSI subsystem initialized
[ 0.049606] libata version 3.00 loaded.
[ 0.049837] usbcore: registered new interface driver usbfs
[ 0.049889] usbcore: registered new interface driver hub
[ 0.049928] usbcore: registered new device driver usb
[ 0.050289] pps_core: LinuxPPS API ver. 1 registered
[ 0.050304] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.050330] PTP clock support registered
[ 0.050456] EDAC MC: Ver: 3.0.0
[ 0.050979] Registered efivars operations
[ 0.051388] FPGA manager framework
[ 0.051510] Advanced Linux Sound Architecture Driver Initialized.
[ 0.052074] NetLabel: Initializing
[ 0.052088] NetLabel: domain hash size = 128
[ 0.052099] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.052158] NetLabel: unlabeled traffic allowed by default
[ 0.052612] clocksource: Switched to clocksource arch_sys_counter
[ 0.052832] VFS: Disk quotas dquot_6.6.0
[ 0.052883] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.058349] NET: Registered PF_INET protocol family
[ 0.058553] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.060213] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.060307] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.060334] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.060454] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.060696] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.060915] MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
[ 0.061000] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.061053] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.061217] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.061644] RPC: Registered named UNIX socket transport module.
[ 0.061677] RPC: Registered udp transport module.
[ 0.061688] RPC: Registered tcp transport module.
[ 0.061698] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.061715] NET: Registered PF_XDP protocol family
[ 0.061736] PCI: CLS 0 bytes, default 64
[ 0.061980] Trying to unpack rootfs image as initramfs…
[ 0.076816] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.077539] kvm [1]: IPA Size Limit: 40 bits
[ 0.078626] kvm [1]: vgic interrupt IRQ9
[ 0.078761] kvm [1]: Hyp mode initialized successfully
[ 0.080119] Initialise system trusted keyrings
[ 0.080416] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.086210] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.086981] NFS: Registering the id_resolver key type
[ 0.087049] Key type id_resolver registered
[ 0.087063] Key type id_legacy registered
[ 0.087177] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.087198] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.087414] 9p: Installing v9fs 9p2000 file system support
[ 0.123891] Key type asymmetric registered
[ 0.123933] Asymmetric key parser ‘x509’ registered
[ 0.333359] Freeing initrd memory: 29676K
[ 0.346902] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.347014] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.347126] io scheduler mq-deadline registered
[ 0.347143] io scheduler kyber registered
[ 0.347192] io scheduler bfq registered
[ 0.347824] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
[ 0.359778] soc soc0: Amlogic Meson GXL (S905X) Revision 21:d (84:2) Detected
[ 0.364399] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.372315] loop: module loaded
[ 0.376689] tun: Universal TUN/TAP device driver, 1.6
[ 0.377375] thunder_xcv, ver 1.0
[ 0.377428] thunder_bgx, ver 1.0
[ 0.377465] nicpf, ver 1.0
[ 0.377814] VFIO - User Level meta-driver version: 0.3
[ 0.379318] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.379353] ehci-pci: EHCI PCI platform driver
[ 0.379395] ehci-platform: EHCI generic platform driver
[ 0.379528] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.379568] ohci-pci: OHCI PCI platform driver
[ 0.379606] ohci-platform: OHCI generic platform driver
[ 0.379984] usbcore: registered new interface driver usb-storage
[ 0.381629] i2c_dev: i2c /dev entries driver
[ 0.383477] sdhci: Secure Digital Host Controller Interface driver
[ 0.383505] sdhci: Copyright(c) Pierre Ossman
[ 0.383871] Synopsys Designware Multimedia Card Interface Driver
[ 0.384724] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.385666] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.386284] efifb: probing for efifb
[ 0.386367] efifb: framebuffer at 0x7fe5b000, using 1620k, total 1620k
[ 0.386384] efifb: mode is 720x576x32, linelength=2880, pages=1
[ 0.386398] efifb: scrolling: redraw
[ 0.386407] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.386820] Console: switching to colour frame buffer device 90x36
[ 0.388827] fb0: EFI VGA frame buffer device
[ 0.389143] meson-sm: secure-monitor enabled
[ 0.389734] hid: raw HID events driver (C) Jiri Kosina
[ 0.389927] usbcore: registered new interface driver usbhid
[ 0.389986] usbhid: USB HID core driver
[ 0.390379] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
[ 0.391170] meson-saradc c1108680.adc: Looking up vref-supply from device tree
[ 0.393616] NET: Registered PF_PACKET protocol family
[ 0.394008] 9pnet: Installing 9P2000 support
[ 0.394129] Key type dns_resolver registered
[ 0.394588] registered taskstats version 1
[ 0.394661] Loading compiled-in X.509 certificates
[ 0.398207] zswap: loaded using pool zstd/z3fold
[ 0.414956] phy phy-d0078020.phy.0: Looking up phy-supply from device tree
[ 0.414979] phy phy-d0078020.phy.0: Looking up phy-supply property in node /soc/apb@d0000000/phy@78020 failed
[ 0.418126] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 22, base_baud = 1500000) is a meson_uart
[ 1.681109] printk: console [ttyAML0] enabled
[ 1.690640] meson-gx-mmc d0074000.mmc: Looking up vmmc-supply from device tree
[ 1.690875] meson-gx-mmc d0074000.mmc: Looking up vqmmc-supply from device tree
[ 1.691105] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
[ 1.691743] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
[ 1.711746] HDMI_5V: 5000 mV, enabled
[ 1.711874] reg-fixed-voltage regulator-hdmi-5v: HDMI_5V supplying 5000000uV
[ 1.712068] VCC_CARD: 1800 <–> 3300 mV at 3300 mV, enabled
[ 1.712358] phy phy-d0078000.phy.1: Looking up phy-supply from device tree
[ 1.712377] HDMI_5V: could not add device link phy-d0078000.phy.1: -ENOENT
[ 1.713581] dwc3-meson-g12a d0078080.usb: Looking up vbus-supply from device tree
[ 1.713604] dwc3-meson-g12a d0078080.usb: Looking up vbus-supply property in node /soc/usb@d0078080 failed
[ 1.713782] dwc3-meson-g12a d0078080.usb: USB2 ports: 2
[ 1.714920] dwc3-meson-g12a d0078080.usb: USB3 ports: 0
[ 1.730219] meson-gx-mmc d0074000.mmc: no support for card’s volts
[ 1.731870] mmc0: error -22 whilst initialising SDIO card
[ 2.239546] dwc2 c9100000.usb: Looking up vusb_d-supply from device tree
[ 2.239568] dwc2 c9100000.usb: Looking up vusb_d-supply property in node /soc/usb@d0078080/usb@c9100000 failed
[ 2.239595] dwc2 c9100000.usb: supply vusb_d not found, using dummy regulator
[ 2.242401] dwc2 c9100000.usb: Looking up vusb_a-supply from device tree
[ 2.242423] dwc2 c9100000.usb: Looking up vusb_a-supply property in node /soc/usb@d0078080/usb@c9100000 failed
[ 2.242452] dwc2 c9100000.usb: supply vusb_a not found, using dummy regulator
[ 2.249577] dwc2 c9100000.usb: Looking up vbus-supply from device tree
[ 2.249596] dwc2 c9100000.usb: Looking up vbus-supply property in node /soc/usb@d0078080/usb@c9100000 failed
[ 2.250906] dwc2 c9100000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
[ 2.261292] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.263418] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 2.270257] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[ 2.276039] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000002002010010
[ 2.286712] xhci-hcd xhci-hcd.0.auto: irq 25, io mem 0xc9000000
[ 2.291542] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 2.300782] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.307244] usb usb1: Product: xHCI Host Controller
[ 2.311265] usb usb1: Manufacturer: Linux 5.19.16-04046-g062726298e8a xhci-hcd
[ 2.318449] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 2.323842] hub 1-0:1.0: USB hub found
[ 2.327053] hub 1-0:1.0: 2 ports detected
[ 2.333113] meson-gx-mmc d0072000.mmc: Looking up vmmc-supply from device tree
[ 2.333287] meson-gx-mmc d0072000.mmc: Looking up vqmmc-supply from device tree
[ 2.333443] meson-gx-mmc d0072000.mmc: Got CD GPIO
[ 2.333530] of_cfs_init
[ 2.339276] of_cfs_init: OK
[ 2.341035] ALSA device list:
[ 2.343678] No soundcards found.
[ 2.375091] Freeing unused kernel memory: 3136K
[ 2.376788] Run /init as init process
[ 2.378939] with arguments:
[ 2.378949] /init
[ 2.378955] noquiet
[ 2.378959] splash
[ 2.378963] with environment:
[ 2.378967] HOME=/
[ 2.378970] TERM=linux
[ 2.378974] BOOT_IMAGE=/boot/vmlinuz-5.19.16-04046-g062726298e8a
[ 2.410979] mmc1: new high speed SDHC card at address 0001
[ 2.414518] mmcblk1: mmc1:0001 EB1QT 29.8 GiB
[ 2.419306] mmcblk1: p1 p2
[ 2.584698] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 2.734313] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[ 2.739080] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.745191] usb 1-1: Product: USB2.0 Hub
[ 2.803894] hub 1-1:1.0: USB hub found
[ 2.805472] hub 1-1:1.0: 4 ports detected
[ 2.809863] simple-framebuffer 7fe5b000.framebuffer: [drm] could not acquire memory region [mem 0x7fe5b000-0x7ffeffff flags 0x200]
[ 2.818578] lima d00c0000.gpu: Looking up mali-supply from device tree
[ 2.819915] lima d00c0000.gpu: Looking up mali-supply property in node /soc/apb@d0000000/gpu@c0000 failed
[ 2.823518] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
[ 2.825790] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
[ 2.831947] meson8b-dwmac c9410000.ethernet: PTP uses main clock
[ 2.838319] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
[ 2.838706] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[ 2.846441] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
[ 2.849903] meson8b-dwmac c9410000.ethernet: DWMAC1000
[ 2.859073] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
[ 2.861381] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
[ 2.868074] mmc0: Card stuck being busy! __mmc_poll_for_busy
[ 2.875392] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
[ 2.875747] [drm] Initialized simpledrm 1.0.0 20200625 for 7fe5b000.framebuffer on minor 0
[ 2.876248] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
[ 2.876266] meson8b-dwmac c9410000.ethernet: COE Type 2
[ 2.876274] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
[ 2.876279] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
[ 2.876402] checking generic (7fe5b000 195000) vs hw (0 0)
[ 2.878818] meson8b-dwmac c9410000.ethernet: Normal descriptors
[ 2.879532] meson8b-dwmac c9410000.ethernet: Ring mode enabled
[ 2.879633] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 2.890954] meson-drm d0100000.vpu: Queued 2 outputs on vpu
[ 2.895588] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[ 2.966108] simple-framebuffer 7fe5b000.framebuffer: [drm] fb1: simpledrmdrmfb frame buffer device
[ 2.973259] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
[ 2.980928] Console: switching to colour dummy device 80x25
[ 3.013022] lima d00c0000.gpu: bus rate = 166666667
[ 3.013078] lima d00c0000.gpu: mod rate = 24000000
[ 3.017149] lima d00c0000.gpu: Looking up mali-supply from device tree
[ 3.017168] lima d00c0000.gpu: Looking up mali-supply property in node /soc/apb@d0000000/gpu@c0000 failed
[ 3.017202] lima d00c0000.gpu: error -ENODEV: dev_pm_opp_set_regulators: no regulator (mali) found
[ 3.029482] lima d00c0000.gpu: Failed to register cooling device
[ 3.032543] [drm] Initialized lima 1.1.0 20191231 for d00c0000.gpu on minor 1
[ 3.073493] meson-dw-hdmi c883a000.hdmi-tx: Looking up hdmi-supply from device tree
[ 3.116858] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[ 3.123776] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[ 3.130657] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[ 3.138324] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 2
[ 3.161502] Console: switching to colour frame buffer device 90x36
[ 3.185382] meson-drm d0100000.vpu: [drm] fb0: mesondrmfb frame buffer device
[ 4.596614] raid6: neonx8 gen() 2372 MB/s
[ 4.664607] raid6: neonx4 gen() 2590 MB/s
[ 4.732635] raid6: neonx2 gen() 2419 MB/s
[ 4.800609] raid6: neonx1 gen() 1805 MB/s
[ 4.868604] raid6: int64x8 gen() 1749 MB/s
[ 4.936612] raid6: int64x4 gen() 1964 MB/s
[ 5.004605] raid6: int64x2 gen() 1672 MB/s
[ 5.072623] raid6: int64x1 gen() 1246 MB/s
[ 5.072694] raid6: using algorithm neonx4 gen() 2590 MB/s
[ 5.144604] raid6: … xor() 1867 MB/s, rmw enabled
[ 5.146278] raid6: using neon recovery algorithm
[ 5.151470] xor: measuring software checksum speed
[ 5.158365] 8regs : 2882 MB/sec
[ 5.163306] 32regs : 2976 MB/sec
[ 5.168365] arm64_neon : 2833 MB/sec
[ 5.169899] xor: using function: 32regs (2976 MB/sec)
[ 5.174293] async_tx: api initialized (async)
[ 5.351125] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
[ 5.485967] BTRFS: device label writable devid 1 transid 2810 /dev/mmcblk1p2 scanned by btrfs (265)
[ 5.624822] BTRFS info (device mmcblk1p2): disk space caching is enabled
[ 5.626018] BTRFS info (device mmcblk1p2): has skinny extents
[ 5.650015] BTRFS info (device mmcblk1p2): enabling ssd optimizations
[ 5.650915] BTRFS info (device mmcblk1p2): start tree-log replay
[ 8.998973] systemd[1]: System time before build time, advancing clock.
[ 9.140993] NET: Registered PF_INET6 protocol family
[ 9.168759] Segment Routing with IPv6
[ 9.168879] RPL Segment Routing with IPv6
[ 9.170894] In-situ OAM (IOAM) with IPv6
[ 9.214697] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 9.242232] systemd[1]: Detected architecture arm64.
[ 9.253433] systemd[1]: Hostname set to .
[ 10.408964] systemd[1]: Queued start job for default target Graphical Interface.
[ 10.439560] systemd[1]: Created slice Slice /system/modprobe.
[ 10.442247] systemd[1]: Created slice Slice /system/serial-getty.
[ 10.450306] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 10.457708] systemd[1]: Created slice User and Session Slice.
[ 10.464251] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.474680] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.489020] systemd[1]: Reached target Slice Units.
[ 10.496077] systemd[1]: Reached target Local Verity Protected Volumes.
[ 10.504856] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 10.514464] systemd[1]: Listening on LVM2 poll daemon socket.
[ 10.525365] systemd[1]: Listening on multipathd control socket.
[ 10.535426] systemd[1]: Listening on Syslog Socket.
[ 10.540693] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 10.549172] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 10.558409] systemd[1]: Listening on Journal Audit Socket.
[ 10.565492] systemd[1]: Listening on Journal Socket (/dev/log).
[ 10.573586] systemd[1]: Listening on Journal Socket.
[ 10.580883] systemd[1]: Listening on Network Service Netlink Socket.
[ 10.589235] systemd[1]: Listening on udev Control Socket.
[ 10.596428] systemd[1]: Listening on udev Kernel Socket.
[ 10.628092] systemd[1]: Mounting Huge Pages File System…
[ 10.640474] systemd[1]: Mounting POSIX Message Queue File System…
[ 10.652257] systemd[1]: Mounting Kernel Debug File System…
[ 10.659050] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 10.673544] systemd[1]: Starting Journal Service…
[ 10.686391] systemd[1]: Starting Set the console keyboard layout…
[ 10.697797] systemd[1]: Starting Create List of Static Device Nodes…
[ 10.710519] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 10.724475] systemd[1]: Condition check resulted in LXD - agent being skipped.
[ 10.732030] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[ 10.745666] systemd[1]: Starting Load Kernel Module configfs…
[ 10.756338] systemd[1]: Starting Load Kernel Module drm…
[ 10.767800] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 10.778347] systemd[1]: Starting Load Kernel Module fuse…
[ 10.789591] systemd[1]: Starting Load Kernel Module pstore_blk…
[ 10.800328] systemd[1]: Starting Load Kernel Module pstore_zone…
[ 10.812336] systemd[1]: Starting Load Kernel Module ramoops…
[ 10.820140] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[ 10.821164] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 10.850848] systemd[1]: Starting Load Kernel Modules…
[ 10.860488] fuse: init (API version 7.36)
[ 10.865528] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 10.879058] systemd[1]: Starting Coldplug All udev Devices…
[ 10.893777] IPMI message handler: version 39.2
[ 10.895049] systemd[1]: Mounted Huge Pages File System.
[ 10.908707] systemd[1]: Started Journal Service.
[ 10.912347] BTRFS info (device mmcblk1p2: state M): use zstd compression, level 3
[ 10.920156] ipmi device interface
[ 10.922026] BTRFS info (device mmcblk1p2: state M): disk space caching is enabled
[ 10.942300] Asymmetric key parser ‘pkcs8’ registered
[ 11.083084] alua: device handler registered
[ 11.097165] systemd-journald[381]: Received client request to flush runtime journal.
[ 11.104352] emc: device handler registered
[ 11.134656] systemd-journald[381]: File /var/log/journal/19fed89fd06009ff03b5e7926329c433/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 11.136035] rdac: device handler registered
[ 11.161467] device-mapper: uevent: version 1.0.3
[ 11.161806] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 11.311613] loop0: detected capacity change from 0 to 120864
[ 11.313696] loop1: detected capacity change from 0 to 118496
[ 11.322035] loop2: detected capacity change from 0 to 147080
[ 11.331843] loop3: detected capacity change from 0 to 85048
[ 11.332084] loop4: detected capacity change from 0 to 208968
[ 11.337383] loop5: detected capacity change from 0 to 85040
[ 13.078463] mc: Linux media interface: v0.10
[ 13.110036] videodev: Linux video capture interface: v2.00
[ 13.127164] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
[ 13.127360] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
[ 13.158214] t9015-codec c8832000.audio-controller: Looking up AVDD-supply from device tree
[ 13.170674] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.191151] Registered IR keymap rc-cec
[ 13.202339] simple-amplifier analog-amplifier: Looking up VCC-supply from device tree
[ 13.209646] Registered IR keymap rc-empty
[ 13.209766] rc rc1: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc1
[ 13.210026] rc rc1: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
[ 13.211052] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc1/input1
[ 13.211405] rc rc0: meson_ao_cec as /devices/platform/soc/c8100000.bus/c8100100.cec/rc/rc0
[ 13.221911] meson-ir c8100580.ir: receiver initialized
[ 13.222994] input: meson_ao_cec as /devices/platform/soc/c8100000.bus/c8100100.cec/rc/rc0/input0
[ 19.864430] meson8b-dwmac c9410000.ethernet eth0: PHY [mdio_mux-0.e40908ff:08] driver [Meson GXL Internal PHY] (irq=38)
[ 19.866145] meson8b-dwmac c9410000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[ 21.383006] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
[ 21.383052] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
[ 21.384204] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
[ 22.894779] meson8b-dwmac c9410000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 22.894840] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 25.114306] Adding 1048572k swap on /swapfile. Priority:-2 extents:1 across:1048572k FS
[ 25.815697] Bluetooth: Core ver 2.22
[ 25.815833] NET: Registered PF_BLUETOOTH protocol family
[ 25.815840] Bluetooth: HCI device and connection manager initialized
[ 25.815858] Bluetooth: HCI socket layer initialized
[ 25.815866] Bluetooth: L2CAP socket layer initialized
[ 25.815884] Bluetooth: SCO socket layer initialized
[ 28.932283] loop6: detected capacity change from 0 to 8
and here is the other Libre board:
[ 0.000000] Memory: 1685272K/2097152K available (12864K kernel code, 1734K rwdata, 5060K rodata, 3136K init, 468K bss, 149736K reserved, 262144K cma-reserved)
[ 0.000527] Console: colour dummy device 80x25
[ 0.001030] printk: console [tty0] enabled
[ 0.001070] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=96000)
[ 0.001094] pid_max: default: 32768 minimum: 301
[ 0.001159] LSM: Security Framework initializing
[ 0.001185] Yama: becoming mindful.
[ 0.001309] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.001336] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.002586] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002625] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002695] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002829] rcu: Hierarchical SRCU implementation.
[ 0.002842] rcu: Max phase no-delay instances is 1000.
[ 0.003833] Remapping and enabling EFI services.
[ 0.004233] smp: Bringing up secondary CPUs …
[ 0.004730] Detected VIPT I-cache on CPU1
[ 0.004800] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.005378] Detected VIPT I-cache on CPU2
[ 0.005436] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.005966] Detected VIPT I-cache on CPU3
[ 0.006018] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.006099] smp: Brought up 1 node, 4 CPUs
[ 0.006168] SMP: Total of 4 processors activated.
[ 0.006180] CPU features: detected: 32-bit EL0 Support
[ 0.006190] CPU features: detected: 32-bit EL1 Support
[ 0.006203] CPU features: detected: CRC32 instructions
[ 0.006672] CPU: All CPU(s) started at EL2
[ 0.006709] alternatives: patching kernel code
[ 0.008017] devtmpfs: initialized
[ 0.013553] Registered cp15_barrier emulation handler
[ 0.013593] Registered setend emulation handler
[ 0.013610] KASLR enabled
[ 0.013810] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.019824] pinctrl core: initialized pinctrl subsystem
[ 0.020180] regulator-dummy: no parameters, enabled
[ 0.020462] SMBIOS 3.0 present.
[ 0.020494] DMI: libre-computer aml-s905x-cc/aml-s905x-cc, BIOS 2022.07+ 07/01/2022
[ 0.020957] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.022160] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.022364] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.022515] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.022603] audit: initializing netlink subsys (disabled)
[ 0.022796] audit: type=2000 audit(0.020:1): state=initialized audit_enabled=0 res=1
[ 0.023816] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.023827] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.024143] cpuidle: using governor menu
[ 0.024363] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.024468] ASID allocator initialised with 32768 entries
[ 0.024484] HugeTLB: can optimize 4095 vmemmap pages for hugepages-1048576kB
[ 0.024498] HugeTLB: can optimize 127 vmemmap pages for hugepages-32768kB
[ 0.024512] HugeTLB: can optimize 7 vmemmap pages for hugepages-2048kB
[ 0.024525] HugeTLB: can optimize 0 vmemmap pages for hugepages-64kB
[ 0.035924] platform c883a000.hdmi-tx: Fixing up cyclic dependency with d0100000.vpu
[ 0.037174] platform cvbs-connector: Fixing up cyclic dependency with d0100000.vpu
[ 0.037571] platform hdmi-connector: Fixing up cyclic dependency with c883a000.hdmi-tx
[ 0.046496] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.046533] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.046547] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.046560] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.047810] fbcon: Taking over console
[ 0.048117] VCC_3V3: 3300 mV, enabled
[ 0.048283] reg-fixed-voltage regulator-vcc_3v3: VCC_3V3 supplying 3300000uV
[ 0.048413] VDDIO_AO18: 1800 mV, enabled
[ 0.048496] reg-fixed-voltage regulator-vddio_ao18: VDDIO_AO18 supplying 1800000uV
[ 0.048595] VDDIO_BOOT: will resolve supply early: vin
[ 0.048601] reg-fixed-voltage regulator-vddio_boot: Looking up vin-supply from device tree
[ 0.048614] VDDIO_BOOT: supplied by VCC_3V3
[ 0.048622] VCC_3V3: could not add device link regulator.3: -ENOENT
[ 0.048678] VDDIO_BOOT: 1800 mV, enabled
[ 0.048759] reg-fixed-voltage regulator-vddio_boot: VDDIO_BOOT supplying 1800000uV
[ 0.049145] iommu: Default domain type: Passthrough
[ 0.049436] SCSI subsystem initialized
[ 0.049593] libata version 3.00 loaded.
[ 0.049825] usbcore: registered new interface driver usbfs
[ 0.049875] usbcore: registered new interface driver hub
[ 0.049916] usbcore: registered new device driver usb
[ 0.050277] pps_core: LinuxPPS API ver. 1 registered
[ 0.050292] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.050318] PTP clock support registered
[ 0.050443] EDAC MC: Ver: 3.0.0
[ 0.050969] Registered efivars operations
[ 0.051376] FPGA manager framework
[ 0.051496] Advanced Linux Sound Architecture Driver Initialized.
[ 0.052060] NetLabel: Initializing
[ 0.052073] NetLabel: domain hash size = 128
[ 0.052084] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.052143] NetLabel: unlabeled traffic allowed by default
[ 0.052830] VFS: Disk quotas dquot_6.6.0
[ 0.052879] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.058374] NET: Registered PF_INET protocol family
[ 0.058575] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.060210] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.060267] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.060330] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.060450] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.060694] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.060912] MPTCP token hash table entries: 2048 (order: 3, 49152 bytes, linear)
[ 0.060998] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.061051] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.061215] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.061645] RPC: Registered named UNIX socket transport module.
[ 0.061676] RPC: Registered udp transport module.
[ 0.061687] RPC: Registered tcp transport module.
[ 0.061697] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.061934] Trying to unpack rootfs image as initramfs…
[ 0.062754] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.063309] kvm [1]: IPA Size Limit: 40 bits
[ 0.064390] kvm [1]: vgic interrupt IRQ9
[ 0.064528] kvm [1]: Hyp mode initialized successfully
[ 0.065928] Initialise system trusted keyrings
[ 0.066207] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[ 0.072015] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.072731] NFS: Registering the id_resolver key type
[ 0.072791] Key type id_resolver registered
[ 0.072803] Key type id_legacy registered
[ 0.072895] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.072913] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.073134] 9p: Installing v9fs 9p2000 file system support
[ 0.110209] Key type asymmetric registered
[ 0.110251] Asymmetric key parser ‘x509’ registered
[ 0.334119] Freeing initrd memory: 29676K
[ 0.347653] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.347766] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.347871] io scheduler mq-deadline registered
[ 0.347887] io scheduler kyber registered
[ 0.347934] io scheduler bfq registered
[ 0.348577] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
[ 0.360498] soc soc0: Amlogic Meson GXL (S905X) Revision 21:d (84:2) Detected
[ 0.365252] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.373206] loop: module loaded
[ 0.377447] tun: Universal TUN/TAP device driver, 1.6
[ 0.378118] thunder_xcv, ver 1.0
[ 0.378174] thunder_bgx, ver 1.0
[ 0.378212] nicpf, ver 1.0
[ 0.378542] VFIO - User Level meta-driver version: 0.3
[ 0.379994] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.380028] ehci-pci: EHCI PCI platform driver
[ 0.380067] ehci-platform: EHCI generic platform driver
[ 0.380193] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.380232] ohci-pci: OHCI PCI platform driver
[ 0.380270] ohci-platform: OHCI generic platform driver
[ 0.380718] usbcore: registered new interface driver usb-storage
[ 0.382297] i2c_dev: i2c /dev entries driver
[ 0.384078] sdhci: Secure Digital Host Controller Interface driver
[ 0.384105] sdhci: Copyright(c) Pierre Ossman
[ 0.384470] Synopsys Designware Multimedia Card Interface Driver
[ 0.385300] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.386190] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.386769] efifb: probing for efifb
[ 0.386852] efifb: framebuffer at 0x7fe5b000, using 1620k, total 1620k
[ 0.386868] efifb: mode is 720x576x32, linelength=2880, pages=1
[ 0.386882] efifb: scrolling: redraw
[ 0.386890] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.387295] Console: switching to colour frame buffer device 90x36
[ 0.389288] fb0: EFI VGA frame buffer device
[ 0.389596] meson-sm: secure-monitor enabled
[ 0.390177] hid: raw HID events driver (C) Jiri Kosina
[ 0.390375] usbcore: registered new interface driver usbhid
[ 0.390431] usbhid: USB HID core driver
[ 0.390822] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
[ 0.391594] meson-saradc c1108680.adc: Looking up vref-supply from device tree
[ 0.394029] NET: Registered PF_PACKET protocol family
[ 0.394360] 9pnet: Installing 9P2000 support
[ 0.394475] Key type dns_resolver registered
[ 0.394938] registered taskstats version 1
[ 0.395010] Loading compiled-in X.509 certificates
[ 0.398586] zswap: loaded using pool zstd/z3fold
[ 0.415265] phy phy-d0078020.phy.0: Looking up phy-supply from device tree
[ 0.415286] phy phy-d0078020.phy.0: Looking up phy-supply property in node /soc/apb@d0000000/phy@78020 failed
[ 0.418404] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 22, base_baud = 1500000) is a meson_uart
[ 1.681376] printk: console [ttyAML0] enabled
[ 1.690770] meson-gx-mmc d0074000.mmc: Looking up vmmc-supply from device tree
[ 1.691010] meson-gx-mmc d0074000.mmc: Looking up vqmmc-supply from device tree
[ 1.691220] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
[ 1.692651] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
[ 1.711731] HDMI_5V: 5000 mV, enabled
[ 1.711863] reg-fixed-voltage regulator-hdmi-5v: HDMI_5V supplying 5000000uV
[ 1.712049] VCC_CARD: 1800 <–> 3300 mV at 3300 mV, enabled
[ 1.712328] phy phy-d0078000.phy.1: Looking up phy-supply from device tree
[ 1.712347] HDMI_5V: could not add device link phy-d0078000.phy.1: -ENOENT
[ 1.713575] dwc3-meson-g12a d0078080.usb: Looking up vbus-supply from device tree
[ 1.713601] dwc3-meson-g12a d0078080.usb: Looking up vbus-supply property in node /soc/usb@d0078080 failed
[ 1.713790] dwc3-meson-g12a d0078080.usb: USB2 ports: 2
[ 1.714933] dwc3-meson-g12a d0078080.usb: USB3 ports: 0
[ 1.731954] meson-gx-mmc d0074000.mmc: no support for card’s volts
[ 1.733657] mmc0: error -22 whilst initialising SDIO card
[ 2.239513] dwc2 c9100000.usb: Looking up vusb_d-supply from device tree
[ 2.239534] dwc2 c9100000.usb: Looking up vusb_d-supply property in node /soc/usb@d0078080/usb@c9100000 failed
[ 2.239560] dwc2 c9100000.usb: supply vusb_d not found, using dummy regulator
[ 2.242373] dwc2 c9100000.usb: Looking up vusb_a-supply from device tree
[ 2.242397] dwc2 c9100000.usb: Looking up vusb_a-supply property in node /soc/usb@d0078080/usb@c9100000 failed
[ 2.242426] dwc2 c9100000.usb: supply vusb_a not found, using dummy regulator
[ 2.249532] dwc2 c9100000.usb: Looking up vbus-supply from device tree
[ 2.249550] dwc2 c9100000.usb: Looking up vbus-supply property in node /soc/usb@d0078080/usb@c9100000 failed
[ 2.250861] dwc2 c9100000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM
[ 2.261311] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.263515] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 2.270083] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[ 2.275892] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000002002010010
[ 2.286336] xhci-hcd xhci-hcd.0.auto: irq 25, io mem 0xc9000000
[ 2.291358] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 2.300347] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.306470] usb usb1: Product: xHCI Host Controller
[ 2.311297] usb usb1: Manufacturer: Linux 5.19.16-04046-g062726298e8a xhci-hcd
[ 2.318482] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 2.323820] hub 1-0:1.0: USB hub found
[ 2.327061] hub 1-0:1.0: 2 ports detected
[ 2.333083] meson-gx-mmc d0072000.mmc: Looking up vmmc-supply from device tree
[ 2.333208] meson-gx-mmc d0072000.mmc: Looking up vqmmc-supply from device tree
[ 2.333351] meson-gx-mmc d0072000.mmc: Got CD GPIO
[ 2.333643] of_cfs_init
[ 2.339285] of_cfs_init: OK
[ 2.341043] ALSA device list:
[ 2.343714] No soundcards found.
[ 2.375086] Freeing unused kernel memory: 3136K
[ 2.376514] Run /init as init process
[ 2.378769] with arguments:
[ 2.378779] /init
[ 2.378785] noquiet
[ 2.378789] splash
[ 2.378792] with environment:
[ 2.378795] HOME=/
[ 2.378798] TERM=linux
[ 2.378802] BOOT_IMAGE=/boot/vmlinuz-5.19.16-04046-g062726298e8a
[ 2.410924] mmc1: new high speed SDHC card at address 0001
[ 2.414491] mmcblk1: mmc1:0001 EB1QT 29.8 GiB
[ 2.420719] mmcblk1: p1 p2
[ 2.588684] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 2.738240] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[ 2.742982] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.749059] usb 1-1: Product: USB2.0 Hub
[ 2.806599] hub 1-1:1.0: USB hub found
[ 2.808107] hub 1-1:1.0: 4 ports detected
[ 2.861095] mmc0: Card stuck being busy! __mmc_poll_for_busy
[ 2.889834] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
[ 2.892176] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
[ 2.898905] meson8b-dwmac c9410000.ethernet: PTP uses main clock
[ 2.905151] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
[ 2.911244] meson8b-dwmac c9410000.ethernet: DWMAC1000
[ 2.913307] meson-drm d0100000.vpu: Queued 2 outputs on vpu
[ 2.913537] lima d00c0000.gpu: Looking up mali-supply from device tree
[ 2.913548] lima d00c0000.gpu: Looking up mali-supply property in node /soc/apb@d0000000/gpu@c0000 failed
[ 2.915212] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
[ 2.917164] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
[ 2.917243] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
[ 2.917313] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
[ 2.917377] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
[ 2.917412] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
[ 2.917423] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
[ 2.919697] simple-framebuffer 7fe5b000.framebuffer: [drm] could not acquire memory region [mem 0x7fe5b000-0x7ffeffff flags 0x200]
[ 2.921288] [drm] Initialized simpledrm 1.0.0 20200625 for 7fe5b000.framebuffer on minor 1
[ 2.921551] lima d00c0000.gpu: bus rate = 166666667
[ 2.921570] lima d00c0000.gpu: mod rate = 24000000
[ 2.921641] lima d00c0000.gpu: Looking up mali-supply from device tree
[ 2.921650] lima d00c0000.gpu: Looking up mali-supply property in node /soc/apb@d0000000/gpu@c0000 failed
[ 2.921680] lima d00c0000.gpu: error -ENODEV: dev_pm_opp_set_regulators: no regulator (mali) found
[ 2.921826] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
[ 2.922394] lima d00c0000.gpu: Failed to register cooling device
[ 2.924267] [drm] Initialized lima 1.1.0 20191231 for d00c0000.gpu on minor 0
[ 2.924580] checking generic (7fe5b000 195000) vs hw (0 0)
[ 2.933403] meson8b-dwmac c9410000.ethernet: COE Type 2
[ 3.039052] simple-framebuffer 7fe5b000.framebuffer: [drm] fb1: simpledrmdrmfb frame buffer device
[ 3.045529] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
[ 3.045543] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
[ 3.045594] Console: switching to colour dummy device 80x25
[ 3.045688] meson8b-dwmac c9410000.ethernet: Normal descriptors
[ 3.067785] meson8b-dwmac c9410000.ethernet: Ring mode enabled
[ 3.067797] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 3.138835] meson-dw-hdmi c883a000.hdmi-tx: Looking up hdmi-supply from device tree
[ 3.168799] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
[ 3.183777] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
[ 3.186494] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops [meson_dw_hdmi])
[ 3.195544] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 2
[ 3.210386] Console: switching to colour frame buffer device 90x36
[ 3.233249] meson-drm d0100000.vpu: [drm] fb0: mesondrmfb frame buffer device
[ 3.632630] raid6: neonx8 gen() 1782 MB/s
[ 3.700612] raid6: neonx4 gen() 2325 MB/s
[ 3.768606] raid6: neonx2 gen() 2455 MB/s
[ 3.836641] raid6: neonx1 gen() 2121 MB/s
[ 3.904610] raid6: int64x8 gen() 1748 MB/s
[ 3.972608] raid6: int64x4 gen() 1962 MB/s
[ 4.040607] raid6: int64x2 gen() 1672 MB/s
[ 4.108609] raid6: int64x1 gen() 1247 MB/s
[ 4.108677] raid6: using algorithm neonx2 gen() 2455 MB/s
[ 4.180604] raid6: … xor() 1716 MB/s, rmw enabled
[ 4.182270] raid6: using neon recovery algorithm
[ 4.187471] xor: measuring software checksum speed
[ 4.194361] 8regs : 2882 MB/sec
[ 4.199265] 32regs : 2976 MB/sec
[ 4.204280] arm64_neon : 2833 MB/sec
[ 4.205786] xor: using function: 32regs (2976 MB/sec)
[ 4.210204] async_tx: api initialized (async)
[ 4.376715] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
[ 4.516185] BTRFS: device label writable devid 1 transid 2713 /dev/mmcblk1p2 scanned by btrfs (264)
[ 4.663408] BTRFS info (device mmcblk1p2): disk space caching is enabled
[ 4.664645] BTRFS info (device mmcblk1p2): has skinny extents
[ 4.687278] BTRFS info (device mmcblk1p2): enabling ssd optimizations
[ 4.688174] BTRFS info (device mmcblk1p2): start tree-log replay
[ 6.267456] systemd[1]: System time before build time, advancing clock.
[ 6.379701] NET: Registered PF_INET6 protocol family
[ 6.408649] Segment Routing with IPv6
[ 6.408756] RPL Segment Routing with IPv6
[ 6.410794] In-situ OAM (IOAM) with IPv6
[ 6.454526] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 6.482377] systemd[1]: Detected architecture arm64.
[ 6.491991] systemd[1]: Hostname set to .
[ 7.618776] systemd[1]: Queued start job for default target Graphical Interface.
[ 7.641860] systemd[1]: Created slice Slice /system/modprobe.
[ 7.644473] systemd[1]: Created slice Slice /system/serial-getty.
[ 7.652652] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 7.659958] systemd[1]: Created slice User and Session Slice.
[ 7.666582] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.676529] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.693649] systemd[1]: Reached target Slice Units.
[ 7.700881] systemd[1]: Reached target Local Verity Protected Volumes.
[ 7.709541] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.718714] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.726878] systemd[1]: Listening on multipathd control socket.
[ 7.736583] systemd[1]: Listening on Syslog Socket.
[ 7.741869] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 7.750460] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 7.761178] systemd[1]: Listening on Journal Audit Socket.
[ 7.766787] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.774949] systemd[1]: Listening on Journal Socket.
[ 7.782202] systemd[1]: Listening on Network Service Netlink Socket.
[ 7.790586] systemd[1]: Listening on udev Control Socket.
[ 7.797791] systemd[1]: Listening on udev Kernel Socket.
[ 7.823607] systemd[1]: Mounting Huge Pages File System…
[ 7.834144] systemd[1]: Mounting POSIX Message Queue File System…
[ 7.845815] systemd[1]: Mounting Kernel Debug File System…
[ 7.852158] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 7.866535] systemd[1]: Starting Journal Service…
[ 7.879879] systemd[1]: Starting Set the console keyboard layout…
[ 7.892750] systemd[1]: Starting Create List of Static Device Nodes…
[ 7.907171] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 7.921833] systemd[1]: Condition check resulted in LXD - agent being skipped.
[ 7.929224] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[ 7.948329] systemd[1]: Starting Load Kernel Module configfs…
[ 7.961281] systemd[1]: Starting Load Kernel Module drm…
[ 7.971658] systemd[1]: Starting Load Kernel Module efi_pstore…
[ 7.983508] systemd[1]: Starting Load Kernel Module fuse…
[ 7.994348] systemd[1]: Starting Load Kernel Module pstore_blk…
[ 8.005235] systemd[1]: Starting Load Kernel Module pstore_zone…
[ 8.016994] systemd[1]: Starting Load Kernel Module ramoops…
[ 8.023245] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[ 8.024159] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 8.055721] fuse: init (API version 7.36)
[ 8.056230] systemd[1]: Starting Load Kernel Modules…
[ 8.073434] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 8.085414] systemd[1]: Starting Coldplug All udev Devices…
[ 8.100244] systemd[1]: Started Journal Service.
[ 8.102493] IPMI message handler: version 39.2
[ 8.131301] ipmi device interface
[ 8.133196] BTRFS info (device mmcblk1p2: state M): use zstd compression, level 3
[ 8.141674] Asymmetric key parser ‘pkcs8’ registered
[ 8.143978] BTRFS info (device mmcblk1p2: state M): disk space caching is enabled
[ 8.240558] alua: device handler registered
[ 8.245339] emc: device handler registered
[ 8.253706] rdac: device handler registered
[ 8.266751] systemd-journald[380]: Received client request to flush runtime journal.
[ 8.291200] systemd-journald[380]: File /var/log/journal/19fed89fd06009ff03b5e7926329c433/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 8.300891] device-mapper: uevent: version 1.0.3
[ 8.301228] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 8.492290] loop0: detected capacity change from 0 to 118496
[ 8.499537] loop1: detected capacity change from 0 to 120864
[ 8.504445] loop2: detected capacity change from 0 to 147080
[ 8.509146] loop3: detected capacity change from 0 to 208968
[ 8.516882] loop4: detected capacity change from 0 to 83208
[ 8.520296] loop5: detected capacity change from 0 to 85040
[ 10.194748] Registered IR keymap rc-cec
[ 10.227079] rc rc0: meson_ao_cec as /devices/platform/soc/c8100000.bus/c8100100.cec/rc/rc0
[ 10.228092] mc: Linux media interface: v0.10
[ 10.232765] Registered IR keymap rc-empty
[ 10.233509] rc rc1: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc1
[ 10.233869] input: meson_ao_cec as /devices/platform/soc/c8100000.bus/c8100100.cec/rc/rc0/input0
[ 10.237519] rc rc1: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
[ 10.242106] t9015-codec c8832000.audio-controller: Looking up AVDD-supply from device tree
[ 10.249688] videodev: Linux video capture interface: v2.00
[ 10.275527] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc1/input1
[ 10.275945] meson-ir c8100580.ir: receiver initialized
[ 10.318136] simple-amplifier analog-amplifier: Looking up VCC-supply from device tree
[ 10.328285] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
[ 10.328433] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
[ 10.332483] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[ 16.988392] meson8b-dwmac c9410000.ethernet eth0: PHY [mdio_mux-0.e40908ff:08] driver [Meson GXL Internal PHY] (irq=39)
[ 16.990102] meson8b-dwmac c9410000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[ 18.535176] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
[ 18.535231] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
[ 18.536385] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
[ 20.219745] meson8b-dwmac c9410000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 20.219803] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 22.261308] Adding 1048572k swap on /swapfile. Priority:-2 extents:1 across:1048572k FS
[ 23.089246] Bluetooth: Core ver 2.22
[ 23.089388] NET: Registered PF_BLUETOOTH protocol family
[ 23.089397] Bluetooth: HCI device and connection manager initialized
[ 23.089415] Bluetooth: HCI socket layer initialized
[ 23.089422] Bluetooth: L2CAP socket layer initialized
[ 23.089450] Bluetooth: SCO socket layer initialized
[ 26.208706] loop6: detected capacity change from 0 to 8
[ 38.436676] rc rc1: two consecutive events of type space
Is this a log when the disconnect happens or just a random capture of the boot? Did you try the SSH timeout/keep-alive stuff?
after the logs the disconnect happened
Are you able to connect back and then check the logs?
no, I’m not able to connect back; connection immediately drop again
Can you log into the physical machine and check the logs rather than over SSH?
no, they are headless
