Enabling uart and spi on renegade
Hi I’m having a hard time figuring out how to use spi and uart on the renegade with the official Raspbian image.
Trying to connect a adxl345 accelerometer over spi and connect to a 3d printer over uart (already using 3 USB ports for cam, WiFi, and touch display) and I don’t really know where to begin. I know I’ll need to use overlays somehow and change the baud rate if possible to 115200 (I think). I can’t find an overlay for uart with ldto, enabling the spi overlays doesn’t seem to do anything. I can see several different uart pins, is the debug the only usable one or is uart1 and uart2 available?
Is there any consolidated start to finish instructions to enable and test functionality? If someone could point me in the right direction it would be much appreciated.
I used a trianglelabs usb adxl345 and it works perfect on a le potato. I imagine it would apply here also
Under the requests section, make separate requests for each item. Le Potato has these overlays completed but Renegade does not since most people use it for server roles.
Thank you, I’ll try again on the potato. First Time around the touch screen wouldn’t work with klipperscreen out of the box and the renegade did. I see several uart and spi overlays on the potato, which spi and uart overlays should I be using?
See the peripheral section.
Got SPI working, got the screen working with the raspian xorg portability files, still cannot connect uarta. Showing ttyAML6 but no comms. The printer uses a 250000 baud rate so I don’t know if that’s the problem. At the end of the day I also realized my user wasn’t in the tty group so I’m going to retest tonight.
If the regular uarta does not work, try uarta-clk81. Please report back your findings.
Uarta works just fine even at 250000 baud. Still cannot connect to my printer but I’ve discovered it’s due to pin mismatch in the klipper firmware build so no fault of the potato. I connected without issue to an esp8266 for testing purposes. Thank you for all your help!
